Installing MacBook Core 2 Duo Memory Cover
  • Add Note x
  • x 39
This keeps the RAM levers out of the way of the battery and secures the hard drive.
Image #1
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
Image #1
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
Image #1
Add Note Edit Step 3 — Memory Cover  ¶
  • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover so you cannot lose them.
Image #1
Add Note Edit Step 4  ¶
  • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Coin
$2.95 · 20 In stock
Related Products
MacBook Memory Cover
$14.95 · 10 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 27 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
