Image #1 Image #2
Add Note Edit Step 41  ¶
  • Insert the longer end of the retaining clip beneath the edge of its recess cut into the LCD bracket.
  • Use the edge of a metal spudger to push the shorter tab on the other side of the retaining clip into the recess cut into the LCD bracket.
  • The second picture shows the LCD bracket properly installed.
Image #1
Add Note Edit Step 42 — Clutch Cover  ¶
  • Remove the three 4.2 mm Phillips screws securing the clutch cover.
Image #1
Add Note Edit Step 43  ¶
  • While holding the display down with one hand, use your other hand to lift the clutch cover off the clutch hinges.
  • It may help to wiggle the clutch cover as you pull it up from the display.
Image #1
Add Note Edit Step 44  ¶
  • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift the clutch cover out of the display assembly.
  • During reassembly, make sure not to pinch the pink and white inverter cable when snapping the clutch cover back into place.
Image #1 Image #2
Add Note Edit Step 45 — Inverter  ¶
  • Slightly lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board.
Image #1 Image #2
Add Note Edit Step 46  ¶
  • Disconnect the white inverter cable from the right end of the inverter board.
Image #1
Add Note Edit Step 47  ¶
  • Remove the inverter board from the display.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Coin
$2.95 · 20 In stock
Plastic Cards
$2.95 · 29 In stock
Related Products
MacBook Display Inverter
$49.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
