Installing MacBook Core 2 Duo Display Data Cable
Replace a worn-out or broken display data cable in your MacBook Core Duo.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace a worn-out or broken display data cable.
Sections
- Battery 2 steps
- Memory Cover 2 steps
- Upper Case 8 steps
- Optical Drive 11 steps
- C-Channel 3 steps
- Display 9 steps
- Front Display Bezel 6 steps
- Clutch Cover 3 steps
- LCD Assembly 9 steps
- Display Data Cable 7 steps
- View:
- Single page
Edit
Step 5
Upper Case
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
The shorter of the three screws goes in the middle.
Page 1 of 8
