Image #1
Add Note Edit Step 33  ¶
  • Open the display until it is perpendicular to the upper case and place it on a table as shown.
  • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
Image #1
Add Note Edit Step 34  ¶
  • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
  • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
Image #1
Add Note Edit Step 35  ¶
  • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
  • Once the two display hinges have cleared the upper case, remove the display and set it aside.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 43 In stock
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 27 In stock
Related Products
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
