Installing MacBook Air 13" Late 2010 AirPort/Bluetooth Card
Replace the AirPort/Bluetooth card in your MacBook Air 13" Late 2010.
  • Add Note x
  • x 3
Use this guide to replace your AirPort/Bluetooth card.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, close your computer and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
Image #1 Image #2
Add Note Edit Step 4 — AirPort/Bluetooth Card  ¶
  • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
Image #1
Add Note Edit Step 5  ¶
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
  • Remove the AirPort/Bluetooth board from the Air.
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 14 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
