Installing MacBook Air 11" Mid 2011 Right Speaker
Replace a blown-out right speaker in your Mid 2011 MacBook Air 11".
  • Add Note x
  • x 4
Rock too hard? Use this guide to replace a blown-out right speaker.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Image #1
Add Note Edit Step 5  ¶
  • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Image #1
Add Note Edit Step 6 — Right Speaker  ¶
  • Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
Image #1
Add Note Edit Step 7  ¶
  • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
  • Pry upward from beneath the wires.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
  • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
