View profile
Teams
Order History
Logout
« Previous
Page 3 of 3
Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Next » « Previous
$2.95 · 50+ In stock
$6.95 · 50+ In stock
$12.95 · 50+ In stock
$99.95 · 12 In stock
$29.95 · 50+ In stock
$29.95 · 16 In stock
$39.95 · 38 In stock
$24.95 · 48 In stock
$24.95 · 16 In stock
1024
