Installing MacBook Air 11" Mid 2011 Heat Sink
Replace the heat sink on your Mid 2011 MacBook Air 11".
  • Add Note x
  • x 3
Use this guide to replace a damaged heat sink or to reapply thermal paste.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • In this step you will disconnect the battery to help avoid shorting out any components during service.
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Image #1
Add Note Edit Step 4 — Solid-State Drive  ¶
  • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
  • Do not lift the end of the SSD excessively.
  • Pull the drive straight out of its socket and remove it from the logic board.
  • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Image #1
Add Note Edit Step 6 — I/O Board Cable  ¶
  • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Image #1
Add Note Edit Step 7  ¶
  • Peel the I/O board cable up from the adhesive securing it to the fan.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
  • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
  • Remove the I/O board cable.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 15 In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
