Installing MacBook Air 11" Mid 2011 Battery
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the battery on your Mid 2011 MacBook Air 11".
  • Add Note x
  • x 6
Use this guide to replace a worn-out battery.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Image #1
Add Note Edit Step 5  ¶
  • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 28 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
