Installing Mac Mini Mid 2010 RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Upgrade the RAM for overall faster performance.
  • Add Note x
  • x 35
Removing the RAM on the mid 2010 Mac Mini is an easy task that requires no tools.
Image #1 Image #2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Image #1
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
Image #1 Image #2
Add Note Edit Step 3 — RAM  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
Related Products
PC3-8500 2 GB RAM Chip
$29.95 · 20 In stock
PC3-8500 1 GB RAM Chip
$14.95 · 50+ In stock
