Installing Mac Mini Late 2012 RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Upgrade the RAM for faster overall performance.
  • Add Note x
  • x 13
Removing the RAM is an easy task that requires no tools.
Image #1 Image #2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Image #1
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
Image #1 Image #2
Add Note Edit Step 3 — RAM  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
Related Products
PC3-12800 2 GB RAM Chip
$49.95 · 2 In stock
PC3-12800 4 GB RAM Chip
$99.95 · 9 In stock
