Lite-On LightScribe SHM-165H6S Drive Belt Replacement
  1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: step 1, image 1 of 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: step 1, image 2 of 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 2, image 1 of 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 2, image 2 of 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 2, image 3 of 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 3, image 1 of 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 4, image 1 of 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 5, image 1 of 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 5, image 2 of 2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: step 6, image 1 of 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: step 6, image 2 of 2
    • Extend the tray so that the belt is accessible.
    • Remove the old belt using tweezers.
  7. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 7, image 1 of 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: step 7, image 2 of 2
    • Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
5 other people completed this guide.
James Biggs
596 Reputation
3 Guides authored
Cal Poly, Team 6-5, Regan Fall 2011 Member of Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Members
6 Guides authored
One Comment
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring”  it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 6,522
