Installing Game Boy Screen
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
User-Contributed Guide
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
How to install a new Game Boy screen.
  • Author: Andrew Tramposch
  • Time required: 30 to 60 Minutes
  • Difficulty: Very difficult
How to install a replacement Game Boy black and white LCD screen.
Image #1
Add Note Edit Step 1 — Outer Case  ¶
  • Remove the 6 screws on the back of the Game Boy system with a #00 Phillips Screw Driver.
    • Some Game Boys may have tri-wing screws securing the back case, rather than Phillips.
  • Place these screws in a safe place.
  • Be careful with these screws as they are easy to strip, and if this happens, they are almost impossible to remove.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Gently separate the front and back of the system, taking special care not to damage the ribbon cable connecting them.
  • Once you can see the ribbon cable, move the screen side down a little bit to expose the ribbon cable connector.
Image #1
Add Note Edit Step 3  ¶
  • Grip the ribbon connector with your thumb and forefinger, pulling gently until the ribbon connector comes out of its socket.
Image #1
Add Note Edit Step 4  ¶
  • The pieces should be completely separated and appear as shown in the image.
  • Note the location of mounting screws for the circuit boards.
Image #1
Add Note Edit Step 5 — Screen  ¶
  • After taking removing the outer case, look only at the front section. This is where the LCD screen lies.
Image #1
Add Note Edit Step 6  ¶
  • To get to the screen which is on the opposite side of the circuit board, remove the 10 screws that connect the board to the outer case. Use a Phillips #00 Screw Driver.
Image #1
Add Note Edit Step 7  ¶
  • Use a plastic opening tool to remove the circuit board from the front part of the external case.
  • Be careful and go around the outside edge until you can easily remove the circuit board.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • At this point you may consider to just replace the entire front circuit board, as this may save time and money. Also it can be very tedious to replace the screen and may be easier overall. Otherwise continue with the guide.
  • Set the plastic outer case aside. Before you flip over the circuit board to reveal the screen, undo a few hooks on that side of the board that hold the screen in place.
  • DO NOT YET ATTEMPT TO PRY THE SCREEN FROM THE CIRCUIT BOARD
Image #1 Image #2 Image #3
Add Note Edit Step 9  ¶
  • Flip the circuit board to the front with the screen and remove the two screws holding the screen to the circuit board. Use a Phillips #00 Screw Driver.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • The last thing holding the screen to the circuit board are two surface mount attachments.
  • At this point if you are capable enough to desolder these surface mounts and then resolder a new screen (same model and components) go for it.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 4S Replacement Battery
iPhone 3G Replacement Battery
$14.95 · 50+ In stock
T6 Torx Screwdriver
Small Suction Cup
$2.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
