Installing Game Boy Micro Battery Cover
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
User-Contributed Guide
  • Author: Jack
  • Time required: 10 minutes
  • Difficulty: Very easy
Use this guide to remove the battery cover and battery from the Game Boy.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Battery Cover  ¶
  • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
  • Once the screw has been loosened, lift the cover off the back of the device.
Add Note Edit Step 2  ¶
  • With the back cover removed, the battery is connected to the device by two wires and a plastic connector.
  • Gently grab the wires.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Carefully pull the wires until the connector comes out of the device.
  • Be careful! Don't pull too hard or you may rip the wires out from the connector.
  • When putting the battery back in the device, make sure the connector is put in exactly the way it came out.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPad 2 Adhesive Strips
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
