Installing Dell Studio 15 Hard Drive
User-Contributed Guide
Follow this guide for instructions on how to remove the hard drive from a Dell Studio 15 laptop, and use the instructions in reverse on how to install a new one.
  • Author: Eric Bentley
  • Time required: 15 minutes
  • Difficulty: Moderate
Here we'll cover how to remove the bottom hatch of the laptop, how to remove the drive caddy, and how to remove the actual hard drive.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Hard Drive  ¶
  • Gather tools and materials
  • Flip over laptop, and remove battery as a safety precaution
Add Note Edit Step 2  ¶
  • If you look at the bottom of the laptop, you will notice that there is a panel that is removable
  • Unscrew the screws that hold the panel in place
    • Unscrew the screws until they are loose. They will not come out of the panel
  • After loosening all the screws, lift the panel up from the main chassis
    • You may need to use a flathead screwdriver to lift the panel
Add Note Edit Step 3  ¶
  • Now we have access to the internals of the laptop, pretty neat
  • If the battery is away from you, the hard drive should be closer towards you on the left
  • Start by removing the screws holding the caddy into the chassis
    • These screws have a more rounded top, and are longer
    • Once loosened, you can remove with your fingers or tweezers, and then set them aside
Add Note Edit Step 4  ¶
  • Now we remove the screws holding the drive to the caddy
    • These screws are have a flatter head, and are shorter
    • These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
    • The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
    • Set these screws aside, apart from the screws we removed in the last step
Add Note Edit Step 5  ¶
  • Now that the screws are removed, the caddy can be removed from the chassis and drive
  • Pull the black tab on the right side of the caddy, and pull up
    • It might take some wiggling but it should come out
Add Note Edit Step 6  ¶
  • Now that the caddy is removed, we can lift the drive out of it's place
  • It should lift out easily, but it will still be attached with a cable
  • Set it aside on top of the optical drive (the metal surface)
Add Note Edit Step 7  ¶
  • Now that the drive is removed, we have to remove the cable connecting it to the motherboard
  • It may be hard to do at first, but there are some groves that you can use to hold on to
  • Pull the connector from the drive gently
    • Wiggling the connector a bit does help a little
Add Note Edit Step 8  ¶
  • If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
  • If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
  • Pull this tab gently in order to remove the cable
    • Again, wiggling also helps
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 4S Replacement Battery
Spudger
$2.95 · 50+ In stock
iFixit Opening Picks set of 6
$6.95 · 37 In stock
