Installing Brother HL-5240 Laser Printer Toner Cartridge
User-Contributed Guide
  • Author: Tyler Davies
  • Time required: 5 to 10 minutes
  • Difficulty: Very easy
This repair guide shows how to install a new toner cartridge.
Image #1
Add Note Edit Step 1 — Drum Unit and Toner Cartridge  ¶
  • Press the front cover release button.
  • Keep the button pressed and pull the cover toward yourself.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • With the front cover in the downward position, the drum & toner unit will be visible.
  • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
Add Note Edit Step 3 — Toner Cartridge  ¶
  • The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge.
  • Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle.
  • DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures. This may cause a decrease in print quality.
Add Note Edit Step 4  ¶
  • Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position.
  • Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit.
  • The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
Popular Products
iPad 3rd Gen Front Panel Assembly
$134.95 · 50+ In stock
Metal Spudger
$2.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Helping Hands
$8.95 · 50+ In stock
SIM Card Eject Tool
