Asus Eee PC 1005HA Hard Drive Replacement
  1. Asus Eee PC 1005HA Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Hard Drive Replacement: step 2, image 1 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 2, image 2 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 2, image 3 of 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Hard Drive Replacement, Keyboard: step 3, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement, Keyboard: step 3, image 2 of 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Hard Drive Replacement: step 4, image 1 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 4, image 2 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 4, image 3 of 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Hard Drive Replacement: step 5, image 1 of 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
  6. Asus Eee PC 1005HA Hard Drive Replacement, Hard Drive: step 6, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement, Hard Drive: step 6, image 2 of 2
    • Flip the laptop over.
    • Remove the four 5.65 mm screws from the bottom of the case.
    • Loosen the captive screw in the RAM compartment cover.
  7. Asus Eee PC 1005HA Hard Drive Replacement: step 7, image 1 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 7, image 2 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 7, image 3 of 3
    • Remove the panel covering the RAM.
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • Gently pull the RAM chip out of its socket.
    • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
  8. Asus Eee PC 1005HA Hard Drive Replacement: step 8, image 1 of 1
    • Remove the single 6.65 mm screw next to the RAM socket.
  9. Asus Eee PC 1005HA Hard Drive Replacement: step 9, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement: step 9, image 2 of 2
    • Flip the laptop back over and open the display.
    • Remove the six 5.5 mm screws from the metal plate beneath the keyboard.
  10. Asus Eee PC 1005HA Hard Drive Replacement: step 10, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement: step 10, image 2 of 2
    • Using a plastic opening tool, carefully detach the five plastic clips securing the upper case.
    • There are two small LEDs in the top edge of the lower casing, near the bottom right of the laptop. Be careful not to damage them as you pry open the plastic clips.
    • Carefully lift the upper case and flip it towards the front of the laptop.
  11. Asus Eee PC 1005HA Hard Drive Replacement: step 11, image 1 of 1
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Slide the trackpad ribbon cable from its socket.
  12. Asus Eee PC 1005HA Hard Drive Replacement: step 12, image 1 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 12, image 2 of 3 Asus Eee PC 1005HA Hard Drive Replacement: step 12, image 3 of 3
    • Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector.
    • Carefully pull the the I/O board ribbon cable from its sockets.
    • Remove the two 4.6 mm screws holding the hard drive in place.
  13. Asus Eee PC 1005HA Hard Drive Replacement: step 13, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement: step 13, image 2 of 2
    • Carefully slide the hard drive away from its socket.
    • Use the attached pull tab to lift the hard drive up and out of the case.
    • When reinstalling the hard drive, be sure that the WiFi antenna cable (visible as a black loop below the disk in the 2nd photo) is not trapped or pinched beneath the drive.
  14. Asus Eee PC 1005HA Hard Drive Replacement: step 14, image 1 of 2 Asus Eee PC 1005HA Hard Drive Replacement: step 14, image 2 of 2
    • Remove the four 3.6 mm screws from the hard drive tray.
    • Remove the hard drive from the tray.
47 other people completed this guide.
Mitchell Cesare
784 Reputation
4 Guides authored
Cal Poly, Team 11-22, Maness Winter 2012 Member of Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Members
12 Guides authored
10 Comments
Good guide! Thx!
Andre ShneideR - Reply
What's the biggest hard drive that will work on this netbook?
Javier Molina - Reply
If I remember correctly, from the manufacturer, 500 GB should work. I had a WD 320 GB in it.
Elias Sunsetlover -
Great tutorial, thanks, I wouldn't have managed to change the drive without it, I couldn't figure out how to remove the keyboard, those latches are tricky...
julx64 - Reply
On the 1005HAB there is a piece of double sided tape under the backspace key on the keyboard. Other than that this guide works on the 1005HAB.
ejhoutman - Reply
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 132
All Time: 99,047
