Installing Apple TV 1st Generation Power Supply
User-Contributed Guide
Replace the power supply in your Apple TV 1st Generation.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Flip the Apple TV over so that the bottom of the unit is facing up.
  • You need to remove the rubber base to get access to the screws.
  • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
  • The rubber base will be hot after heating, take extreme while proceeding.
  • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
  • Repeat the procedure described above until the rubber base has been completely removed.
Image #1
Add Note Edit Step 2  ¶
  • Remove the four T10 Torx screws securing the lower case to the upper case.
Image #1
Add Note Edit Step 3  ¶
  • Lift and remove the lower case from the upper case.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Carefully pull the hard drive data cable straight up from its socket on the logic board.
  • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board. Otherwise, during boot-up you will see a flashing question mark "?".
Image #1
Add Note Edit Step 5 — AirPort Card  ¶
  • Pry the AirPort antenna cables straight up from their sockets on the logic board.
Image #1
Add Note Edit Step 6  ¶
  • Remove the single T8 Torx screw securing the AirPort card to the logic board.
Image #1
Add Note Edit Step 7  ¶
  • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
Image #1
Add Note Edit Step 8 — Power Supply  ¶
  • Disconnect the power cable straight up from its socket on the logic board.
  • There is a release tab that must be pushed inwards in conjunction with pulling to release the power cable
  • Make sure to pull the connector straight up from its socket and not toward the face of the logic board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
T10 Torx Security Bit Screwdriver
Popular Products
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 45 In stock
iPhone 4S Earpiece Speaker
$24.95 · 36 In stock
26 Bit Driver Kit
$19.95 · 43 In stock
Detailing Brush
$2.95 · 23 In stock
Precision Screw Extractor Set
$19.95 · 50+ In stock
