Installing 1998-2002 Honda Accord Headlights
Replace the headlight in a '98-'02 Honda Accord
- Author: Miroslav Djuric
- Time required: 30 to 45 minutes
- Difficulty: Moderate
Replace a shattered or fogged headlight unit in your '98-'02 Honda Accord.
- View:
- Single page
Edit
Step 3
Front Bumper
Locate and remove the bolts in the front of the wheel well on the either side of the car using a #1 Phillips screw driver or an 8 mm socket wrench.
Locate the bolts on the bottom of both corners of the bumper and remove them using an 8 mm socket wrench or box end wrench.
Edit
Step 6
Headlights
Remove the three 10 mm hex bolts securing the headlight bracket by turning them counter-clockwise with either a socket wrench or box end wrench,
One bolt will be under the outer edge of the headlight. The remaining two bolts will be located under the headlight with the bolt heads pointed towards the side panels.
Remove the headlight bracket by pulling it straight out.
Page 1 of 1
