Insignia Sport NS-4V17 Scroll Wheel Replacement
  1. Insignia Sport NS-4V17 Scroll Wheel Replacement, Battery: step 1, image 1 of 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 2, image 1 of 2 Insignia Sport NS-4V17 Scroll Wheel Replacement: step 2, image 2 of 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 4, image 1 of 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: step 5, image 1 of 2 Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: step 5, image 2 of 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 6, image 1 of 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 7, image 1 of 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: step 7, image 2 of 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: step 7, image 3 of 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 8, image 1 of 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Scroll Wheel Replacement, Scroll Wheel: step 9, image 1 of 1
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  10. Insignia Sport NS-4V17 Scroll Wheel Replacement: step 10, image 1 of 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: step 10, image 2 of 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: step 10, image 3 of 3
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
Wesley Ballar
88 Reputation
4 Guides authored
Cal Poly, Team 12-36, Amido Spring 2013 Member of Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 9
All Time: 451
