Insignia NS-DS9PDVD15 Disc Reader Replacement
  1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: step 1, image 1 of 2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 2, image 1 of 2 Insignia NS-DS9PDVD15 Disc Reader Replacement: step 2, image 2 of 2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 3, image 1 of 1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 4, image 1 of 2 Insignia NS-DS9PDVD15 Disc Reader Replacement: step 4, image 2 of 2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 5, image 1 of 3 Insignia NS-DS9PDVD15 Disc Reader Replacement: step 5, image 2 of 3 Insignia NS-DS9PDVD15 Disc Reader Replacement: step 5, image 3 of 3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: step 6, image 1 of 2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: step 6, image 2 of 2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 7, image 1 of 1
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Reader: step 8, image 1 of 1
    • Locate the disk reader, it will be right under the disk chamber.
  9. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 9, image 1 of 1
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  10. Insignia NS-DS9PDVD15 Disc Reader Replacement: step 10, image 1 of 1
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 589
