Insignia NS-DS9PDVD15 Screen Replacement
  1. Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: step 1, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15  Screen Replacement: step 2, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 2, image 2 of 2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15  Screen Replacement: step 3, image 1 of 1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15  Screen Replacement: step 4, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 4, image 2 of 2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15  Screen Replacement: step 5, image 1 of 3 Insignia NS-DS9PDVD15  Screen Replacement: step 5, image 2 of 3 Insignia NS-DS9PDVD15  Screen Replacement: step 5, image 3 of 3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: step 6, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: step 6, image 2 of 2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15  Screen Replacement: step 7, image 1 of 1
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15  Screen Replacement, Screen: step 8, image 1 of 1
    • After the bottom cover and disk tray have been removed, remove the back panel from the top half.
    • There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
  9. Insignia NS-DS9PDVD15  Screen Replacement: step 9, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 9, image 2 of 2
    • Once all the screws are removed, pry off the cover with the pry tool.
    • You'll see the PC board, back of the speakers, and the back of the screen.
  10. Insignia NS-DS9PDVD15  Screen Replacement: step 10, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 10, image 2 of 2
    • Remove the ribbon cable carefully with the pry tool.
    • First, push out the black portion.
  11. Insignia NS-DS9PDVD15  Screen Replacement: step 11, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 11, image 2 of 2
    • Next, push out the 'ribbon' with the pry tool.
  12. Insignia NS-DS9PDVD15  Screen Replacement: step 12, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 12, image 2 of 2
    • Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
  13. Insignia NS-DS9PDVD15  Screen Replacement: step 13, image 1 of 2 Insignia NS-DS9PDVD15  Screen Replacement: step 13, image 2 of 2
    • After the screws and washers are removed, you can lift the screen off with the pry tool.
One Comment
what is the model of the LCD Panel?
Justin Frost - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 708
