Insignia Flex 10.1 NS-P10A7100 Battery Replacement
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: step 1, image 1 of 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: step 1, image 2 of 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: step 1, image 3 of 3
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 2, image 1 of 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 2, image 2 of 2
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 3, image 1 of 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 3, image 2 of 2
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 4, image 1 of 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 4, image 2 of 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: step 4, image 3 of 3
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
Hannah
289 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 980
