Turn on your mirror to see which light bulb is not working.
Now that you know which bulb isn't working, turn off the mirror and disconnect it from the wall outlet to avoid any injuries.
Turn the light bulb counter clockwise to remove it from the mirror.
Make sure the light bulb that you bought is the same model and wattage as the one you removed.
Place the new light bulb in its socket and turn it clockwise to secure it.
Make sure that the bulb is secured in place.
If it's not well-secured, the bulb won't light up when the mirror is turned on.
Plug the mirror back into the outlet.
Turn on the mirror and check that the new bulb works.
with 1 other contributor
157 Reputation
1 Guide authored
Badges: 2
CSULA-HARRIS-S21S1G80
1 Member
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 42
All Time: 887
