Ibanez 5 String Bass Model SR405QM Output Jack Replacement
Student-Created Guide
An awesome student from our education program made this guide. It is not managed by iFixit staff.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Replacing the output jack.
In this guide you will learn how to replace the output jack. Output jack replacement will need to be done if your bass no longer makes sound, the bass only makes sound when the cable is orientated awkwardly or the bass cuts in and out when the cable is moved. Your output jack can break because the delicate metal parts which make contact with the instrument cable have been worn out or bent out of shape. Sadly this Ibanez series bass uses a closed output jack, thus it is impossible to fix, and can only be replaced.
Sections
Image #1
Edit Step 1 Battery  ¶
  • Gently place the instrument upside-down on a soft surface.
  • Locate the battery cavity cap and screws.
Image #1
Edit Step 2  ¶
  • Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
Image #1
Edit Step 3  ¶
  • Remove the cap by lifting upwards to reveal the battery.
Image #1
Edit Step 4  ¶
  • Gently lift the battery from the cavity.
  • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Image #1
Edit Step 5 Back Plate  ¶
  • Locate back plate cap and screws.
Image #1
Edit Step 6  ¶
  • Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise.
Image #1
Edit Step 7  ¶
  • Remove cap by lifting upwards, revealing the circuitry of the instrument.
Image #1
Edit Step 8 Output Jack  ¶
  • Lift the green printed circuit board to move some of the wires
  • Locate the output jack at the base of the cavity.
  • Move wires away from the end of the output jack to expose the three pins.
Image #1
Edit Step 9  ¶
  • Locate the gold nut at the base of the output Jack.
  • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
  • Use the wrench to loosen the nut.
Image #1
Edit Step 10  ¶
  • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
  • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
Image #1
Edit Step 11  ¶
  • Remove the loosened nut completely by rotating it counter-clockwise.
Image #1
Edit Step 12  ¶
  • Flip the bass over.
  • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
  • Insert a new output jack and tighten the nut about halfway.
Image #1
Edit Step 13  ¶
  • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
  • Securely tighten the nut using the adjustable wrench.
To reassemble your device, follow steps 1-7 in reverse order.
For more information, check out the Ibanez 5 String Bass Model SR405QM device page.
Required Tools
Phillips #2 Screwdriver
$4.95 · 13 In stock
Soldering Workstation
$49.95 · 45 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
iFixit Lock Pick Set
Inspection Scope
$39.95 · 50+ In stock
Frictionless Ratchet
$24.95 · 50+ In stock
Portable Anti-Static Mat
$34.95 · 39 In stock
Popular Products
iPad 2 Bluetooth/Wi-Fi Antenna
iPhone 4S Replacement Battery
$24.95 · 41 In stock
iPhone 5 Home Button
$6.95 · 35 In stock
iPhone 5s Replacement Battery
$24.95 · 8 In stock
Heavy-Duty Spudger
$4.95 · 50+ In stock
Comments Comments are onturn off
No comments.
Today: 5
This Week: 17
This Month: 130
All Time: 840
