Hytera TC-580 Speaker Replacement
  1. Hytera TC-580 Speaker Replacement, Battery: step 1, image 1 of 2 Hytera TC-580 Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: step 2, image 1 of 2 Hytera TC-580 Speaker Replacement: step 2, image 2 of 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: step 3, image 1 of 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: step 4, image 1 of 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: step 6, image 1 of 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: step 7, image 1 of 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: step 8, image 1 of 2 Hytera TC-580 Speaker Replacement: step 8, image 2 of 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: step 9, image 1 of 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: step 10, image 1 of 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: step 11, image 1 of 3 Hytera TC-580 Speaker Replacement, Speaker: step 11, image 2 of 3 Hytera TC-580 Speaker Replacement, Speaker: step 11, image 3 of 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: step 12, image 1 of 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Mohammed Chehab
88 Reputation
1 Guide authored
USF Tampa, Team S3-G4, Nance Spring 2018 Member of USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 514
