Husqvarna Trimmer Carburetor Replacement
  1. Husqvarna Trimmer Carburetor Replacement, Husqvarna Trimmer Carburetor: step 1, image 1 of 1
    • Allow time for the engine to cool before beginning this procedure.
    • Using your fingers, unscrew the air filter bolt and remove it from the filter cover.
  2. Husqvarna Trimmer Carburetor Replacement: step 2, image 1 of 3 Husqvarna Trimmer Carburetor Replacement: step 2, image 2 of 3 Husqvarna Trimmer Carburetor Replacement: step 2, image 3 of 3
    • Pull off the filter cover to reveal the air filter.
    • Remove the air filter from the filter housing.
  3. Husqvarna Trimmer Carburetor Replacement: step 3, image 1 of 2 Husqvarna Trimmer Carburetor Replacement: step 3, image 2 of 2
    • Remove two 8mm nuts with an 8mm socket attached to a 1/4" ratchet turning the nuts counterclockwise.
  4. Husqvarna Trimmer Carburetor Replacement: step 4, image 1 of 2 Husqvarna Trimmer Carburetor Replacement: step 4, image 2 of 2
    • Slide the choke lever to the full choke position.
  5. Husqvarna Trimmer Carburetor Replacement: step 5, image 1 of 3 Husqvarna Trimmer Carburetor Replacement: step 5, image 2 of 3 Husqvarna Trimmer Carburetor Replacement: step 5, image 3 of 3
    • Remove the plastic housing by pulling it away from the device.
  6. Husqvarna Trimmer Carburetor Replacement: step 6, image 1 of 2 Husqvarna Trimmer Carburetor Replacement: step 6, image 2 of 2
    • Pull the carburetor off of the bolts.
  7. Husqvarna Trimmer Carburetor Replacement: step 7, image 1 of 3 Husqvarna Trimmer Carburetor Replacement: step 7, image 2 of 3 Husqvarna Trimmer Carburetor Replacement: step 7, image 3 of 3
    • Detach the throttle cable from the carburetor by tilting it 90 degrees and pulling up.
  8. Husqvarna Trimmer Carburetor Replacement: step 8, image 1 of 2 Husqvarna Trimmer Carburetor Replacement: step 8, image 2 of 2
    • Remove the two fuel lines attached to the bottom of the carburetor using a set of needle nose pliers.
    • Gas may splash when removing fuel lines.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 1,972
