Introduction
If you have difficulty being heard clearly on your Huawei SnapTo G-620, then the microphone may need to be replaced. This guide shows you how to replace your SnapTo's microphone.
Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
Use a plastic opening tool to remove the pictured flat-top connector.
Using the plastic opening tool remove the camera.
