How to use the 2010-2017 Suzuki Swift emergency jack
  1. How to use the 2010-2017 Suzuki Swift emergency jack, retrieve jack: step 1, image 1 of 3 How to use the 2010-2017 Suzuki Swift emergency jack, retrieve jack: step 1, image 2 of 3 How to use the 2010-2017 Suzuki Swift emergency jack, retrieve jack: step 1, image 3 of 3
    • Open the boot, turn over the floor and retrieve the jack crank and the tire iron.
    • Open the compartment where the jack is located.
    • Using the jack crank, turn the jack axle counter clockwise to unsecure it from the compartment and pull it out.
  2. How to use the 2010-2017 Suzuki Swift emergency jack, position jack: step 2, image 1 of 2 How to use the 2010-2017 Suzuki Swift emergency jack, position jack: step 2, image 2 of 2
    • There are 4 u-shaped jack supports underneath the car, located next to each wheel.
    • Turn the jack axle by hand until the support slot of the jack can be placed on the support.
    • Only use the emergency jack on the jack supports.
    • Make sure the car is on a hard level surface.
    • Make sure the jack has at least 51mm load free displacement from its starting position.
  3. How to use the 2010-2017 Suzuki Swift emergency jack, jack up the car: step 3, image 1 of 2 How to use the 2010-2017 Suzuki Swift emergency jack, jack up the car: step 3, image 2 of 2
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Make sure no people are in the car when the car is jacked up.
    • Place the jack crank on the jack axle, and using the tire iron, turn clockwise.
    • Stop cranking when the wheel is high enough from the ground to be replaced.
    • Do not go underneath the car while it is jacked up with the emergency jack.
Follow these instructions in reverse order to lower the car and put the tools back.
knipwim
8,527 Reputation
30 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 68
Past 30 Days: 283
All Time: 13,308
