Introduction
Depending on the work that needs to be done, you want either front or back jacked up, or both. This guide will show the latter.
Jacking up the back first provides some more room for the jack at the front.
Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
To lower the car, follow these instructions in reverse order.
