How to remodel and fix an Old Medicine Cabinet.
  1. How to remodel and fix an Old Medicine Cabinet., How to remodel and fix an Old Medicine Cabinet.: step 1, image 1 of 3 How to remodel and fix an Old Medicine Cabinet., How to remodel and fix an Old Medicine Cabinet.: step 1, image 2 of 3 How to remodel and fix an Old Medicine Cabinet., How to remodel and fix an Old Medicine Cabinet.: step 1, image 3 of 3
    • Remove four screws using a screw driver.
    • Make sure to save the screws for reassembly.
  2. How to remodel and fix an Old Medicine Cabinet.: step 2, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 2, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 2, image 3 of 3
    • After the top of cabinet is off, remove the screws on the left side of cabinet.
    • Save the screws for reassembly.
  3. How to remodel and fix an Old Medicine Cabinet.: step 3, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 3, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 3, image 3 of 3
    • After finishing the left side of cabinet, do the right side.
    • Remove the screws on the right wall of cabinet.
    • Save screws for reassembly.
  4. How to remodel and fix an Old Medicine Cabinet.: step 4, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 4, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 4, image 3 of 3
    • Turn the cabinet over so that it's easier to unscrew the screws from the bottom of cabinet.
  5. How to remodel and fix an Old Medicine Cabinet.: step 5, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 5, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 5, image 3 of 3
    • Now the back wall of cabinet needs to be removed.
    • It's screwed in by little nails. To remove the back wall, use a flathead screwdriver.
    • The flathead screwdriver is an option, there are other tools that can be used.
  6. How to remodel and fix an Old Medicine Cabinet.: step 6, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 6, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 6, image 3 of 3
    • The cabinet doors are left with the knobs.
    • Unscrew the knobs.
    • Save the knobs for reassembly.
  7. How to remodel and fix an Old Medicine Cabinet.: step 7, image 1 of 2 How to remodel and fix an Old Medicine Cabinet.: step 7, image 2 of 2
    • Take the top wall of medicine cabinet and use sandpaper to sand it.
    • Smooth out all the rough edges and bumps.
    • For best results, use sandpaper to get the old paint off.
  8. How to remodel and fix an Old Medicine Cabinet.: step 8, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 8, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 8, image 3 of 3
    • Take the left wall and right wall of cabinet and the two doors of cabinet.
    • Sand the walls and doors of the cabinet.
  9. How to remodel and fix an Old Medicine Cabinet.: step 9, image 1 of 2 How to remodel and fix an Old Medicine Cabinet.: step 9, image 2 of 2
    • Take bottom piece of cabinet and the back wall of cabinet.
    • Use same directions as in step 7.
  10. How to remodel and fix an Old Medicine Cabinet.: step 10, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 10, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 10, image 3 of 3
    • Take the doors of cabinet and sand them down.
    • Sand down the area, where the knobs were.
  11. How to remodel and fix an Old Medicine Cabinet.: step 11, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 11, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 11, image 3 of 3
    • After sanding down the top wall of cabinet and back wall, it is time to spray paint.
    • Use color of your choice but make sure it is for wood.
    • Spray paint and wait at least 3-4 hours to dry before painting other sides.
    • Make sure to wear a mask if you have asthma.
  12. How to remodel and fix an Old Medicine Cabinet.: step 12, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 12, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 12, image 3 of 3
    • Take the doors of cabinets.
    • Spray paint them as well.
    • In here the colors are pink and blue.
    • Make sure to wait 3-4 hours after painting, before painting the other side of doors.
  13. How to remodel and fix an Old Medicine Cabinet.: step 13, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 13, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 13, image 3 of 3
    • Take the left and right side walls of cabinet.
    • Use color of choice.
    • Make sure it's for wood.
    • Wait 3-4 hours after painting to dry, before painting other side.
  14. How to remodel and fix an Old Medicine Cabinet.: step 14, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 14, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 14, image 3 of 3
    • After the painting is done and the drying, it is time to fix some of the holes.
    • The back wall of cabinet has holes that need to be filled in.
    • Take a spatula and wood filler and carefully fill the holes in.
    • Leave to dry.
    • The wood filler can be used before painting the wall, that way time and paint is saved.
  15. How to remodel and fix an Old Medicine Cabinet.: step 15, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 15, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 15, image 3 of 3
    • After wood filler has dried make sure to sand it.
    • Make the areas that were filled, nice and smooth, spray paint will not cover up bumps.
    • After all areas are nice and smooth, use paint color of choice.
    • Make sure the paint is for wood.
    • Spray paint and wait 3-4 hours to dry before painting other side.
  16. How to remodel and fix an Old Medicine Cabinet.: step 16, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 16, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 16, image 3 of 3
    • After the rest of cabinet has dried, it is time to decorate.
    • Make sure to have rollers, one for different color of paint.
    • The paint used here is blue and pink acrylic stencil paint, good on wood.
    • Decorating cabinet is an option, it is not a requirement.
  17. How to remodel and fix an Old Medicine Cabinet.: step 17, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 17, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 17, image 3 of 3
    • Plastic plates are used to pour paint into.
    • Take a roller and dip it into paint.
    • Take stencil of your choice and place it onto the wood and use roller to fill the stencil space in with paint.
    • Use a a different plate for the pink paint and use a new roller.
    • Do the same thing with pink paint as was done with the blue.
  18. How to remodel and fix an Old Medicine Cabinet.: step 18, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 18, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 18, image 3 of 3
    • Now take the doors after they have dried and decorate them both as well.
    • This time use white paint or color of your own choice.
    • Take stencil and fill in the space with the white paint.
    • Remember to have a place to pour the paint and use a new roller for the new paint color.
    • Do this for both doors.
    • Designs can be done on both sides of the doors, not just the front side.
  19. How to remodel and fix an Old Medicine Cabinet.: step 19, image 1 of 3 How to remodel and fix an Old Medicine Cabinet.: step 19, image 2 of 3 How to remodel and fix an Old Medicine Cabinet.: step 19, image 3 of 3
    • The final step is to attach the knobs on the cabinet doors.
    • In this step, new knobs were purchased and are used.
    • Screw in the knobs, a screwdriver is not needed, hands can be used.
    • The old knobs can also be reused and remodeled or new ones can be purchased as was demonstrated.
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 38
All Time: 819
