Canon Powershot SD790 IS Disassembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 1 of 3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 2 of 3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 3 of 3
    • 1. Use a Phillips #0 screwdriver to remove the six screws from the sides of the camera. 2. Hold the mini-USB cover open. Gently grip and remove the side cover. 3. Grip the camera from the sides and carefully remove the screen cover.
  2. Canon Powershot SD790 IS Disassembly: step 2, image 1 of 2 Canon Powershot SD790 IS Disassembly: step 2, image 2 of 2
    • Hold the mini-USB cover open.
    • Gently grip and remove the side cover.
  3. Canon Powershot SD790 IS Disassembly: step 3, image 1 of 3 Canon Powershot SD790 IS Disassembly: step 3, image 2 of 3 Canon Powershot SD790 IS Disassembly: step 3, image 3 of 3
    • Grip the camera from the sides and carefully remove the screen cover.
    • Start at the bottom edge and slowly lift up the cover.
    • Be very careful removing the cover in the area with the camera/video switch.
    • Remove the front cover while continuing to grip the sides of the camera.
    • After removing the screen cover, remove the screw by the power switch that anchors the side plate to separate the sides from the camera.
3 other people completed this guide.
Stanley
372 Reputation
4 Guides authored
Cal Poly, Team 4-33, Regan Winter 2011 Member of Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 5,292
