How to clean Nokia 3120
  1. How to clean Nokia 3120, Battery Installation: step 1, image 1 of 3 How to clean Nokia 3120, Battery Installation: step 1, image 2 of 3 How to clean Nokia 3120, Battery Installation: step 1, image 3 of 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. How to clean Nokia 3120: step 2, image 1 of 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. How to clean Nokia 3120, Face Plate: step 3, image 1 of 3 How to clean Nokia 3120, Face Plate: step 3, image 2 of 3 How to clean Nokia 3120, Face Plate: step 3, image 3 of 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. How to clean Nokia 3120, How to clean Nokia 3120: step 4, image 1 of 1
    • If dirt has gotten inside the phone, both the lens and the case should be cleaned.
    • Once the screen is exposed, spray cleaning solution onto a soft cloth and wipe the screen.
    • Make sure to thoroughly dry the screen.
  5. How to clean Nokia 3120: step 5, image 1 of 1
    • Repeat the cleaning process on the clear plastic connected to the face-plate.
    • If the screen still appears dirty after a thorough cleaning, parts may have to be replaced. See the troubleshooting guide.
2 other people completed this guide.
Rashmili Vemula
23 Reputation
1 Guide authored
Clemson, Team 13-2, Benson Spring 2013 Member of Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 13
Past 30 Days: 16
All Time: 833
