How to Unclog a Keurig BVMC-KG5
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: step 1, image 1 of 1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: step 2, image 1 of 1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: step 3, image 1 of 3 How to Unclog a Keurig BVMC-KG5: step 3, image 2 of 3 How to Unclog a Keurig BVMC-KG5: step 3, image 3 of 3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: step 4, image 1 of 1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: step 5, image 1 of 1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
2 other people completed this guide.
Hunter Ashbrook
155 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 5,658
