How to True a Bent Bicycle Rim Using Common Tools
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: step 1, image 1 of 1
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: step 2, image 1 of 3 How to True a Bent Bicycle Rim Using Common Tools: step 2, image 2 of 3 How to True a Bent Bicycle Rim Using Common Tools: step 2, image 3 of 3
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: step 3, image 1 of 2 How to True a Bent Bicycle Rim Using Common Tools: step 3, image 2 of 2
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: step 4, image 1 of 3 How to True a Bent Bicycle Rim Using Common Tools: step 4, image 2 of 3 How to True a Bent Bicycle Rim Using Common Tools: step 4, image 3 of 3
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: step 5, image 1 of 2 How to True a Bent Bicycle Rim Using Common Tools: step 5, image 2 of 2
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: step 6, image 1 of 2 How to True a Bent Bicycle Rim Using Common Tools: step 6, image 2 of 2
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: step 7, image 1 of 1
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
Charles Tweedy
145 Reputation
1 Guide authored
UCD-MORRIS-S23S1G4 Member of UCD-MORRIS-S23S1G4
Community
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 50
All Time: 357
