How to Switch the Door Swing
  1. How to Switch the Door Swing, Unfasten the door: step 1, image 1 of 1
    • Use a T25 Torx driver to remove the four 15.4 mm‑long screws holding the door hinge to the front panel.
  2. How to Switch the Door Swing, Remove the door: step 2, image 1 of 1
    • Slide the door hinge plate up and remove the door.
  3. How to Switch the Door Swing, Unfasten the strike: step 3, image 1 of 1
    • Use a T25 Torx driver to remove the six 15.4 mm‑long screws securing the strike.
  4. How to Switch the Door Swing, Remove the strike: step 4, image 1 of 3 How to Switch the Door Swing, Remove the strike: step 4, image 2 of 3 How to Switch the Door Swing, Remove the strike: step 4, image 3 of 3
    • Slide the strike up and toward you to remove it.
  5. How to Switch the Door Swing, Unfasten the inner door face: step 5, image 1 of 1
    • Lay the door face down on a towel or blanket before continuing to prevent any damage to the finish.
    • Use a Phillips #2 driver to remove the ten 17.6 mm‑long screws securing the inner door face.
  6. How to Switch the Door Swing, Remove the inner door face: step 6, image 1 of 3 How to Switch the Door Swing, Remove the inner door face: step 6, image 2 of 3 How to Switch the Door Swing, Remove the inner door face: step 6, image 3 of 3
    • Be careful performing this step, as the door glass will be also be lifted. It will be heavy and awkward.
    • Lift the inner door face off the door frame.
  7. How to Switch the Door Swing, Unfasten the hinge: step 7, image 1 of 1
    • Use a T25 Torx driver to remove the five 15.4 mm‑long screws securing the hinge.
  8. How to Switch the Door Swing, Remove the hinge: step 8, image 1 of 3 How to Switch the Door Swing, Remove the hinge: step 8, image 2 of 3 How to Switch the Door Swing, Remove the hinge: step 8, image 3 of 3
    • Slide the hinge out of its slot in the door and remove it.
    • You may find it easier to remove the hinge with it propped up, as the whole assembly is cumbersome to hold.
  9. How to Switch the Door Swing, Unfasten the catch: step 9, image 1 of 3 How to Switch the Door Swing, Unfasten the catch: step 9, image 2 of 3 How to Switch the Door Swing, Unfasten the catch: step 9, image 3 of 3
    • Lay the door face down before continuing.
    • Use a T25 Torx driver to remove the three 15.4 mm‑long screws securing the catch plate and cover.
    • Remove the catch cover. The catch plate will fall off and rest inside the door frame.
  10. How to Switch the Door Swing, Remove the catch plate: step 10, image 1 of 2 How to Switch the Door Swing, Remove the catch plate: step 10, image 2 of 2
    • Slide the catch cover off the door and remove it.
    • The catch plate will fall off and rest inside the door frame.
  11. How to Switch the Door Swing, Remove the catch plate: step 11, image 1 of 2 How to Switch the Door Swing, Remove the catch plate: step 11, image 2 of 2
    • While lifting up the door face, remove the catch plate.
    • Set it aside with the catch plate cover. You'll use it during reassembly.
  12. How to Switch the Door Swing, Replace the hinge: step 12, image 1 of 3 How to Switch the Door Swing, Replace the hinge: step 12, image 2 of 3 How to Switch the Door Swing, Replace the hinge: step 12, image 3 of 3
    • Place the hinge into the position where you just removed the catch plate and catch cover.
    • The rounded rectangular boss will help you align the hinge.
    • Use a T25 Torx driver to replace the five 15.4 mm‑long screws securing the hinge.
  13. How to Switch the Door Swing, Replace the catch plate: step 13, image 1 of 2 How to Switch the Door Swing, Replace the catch plate: step 13, image 2 of 2
    • With the inner door face lying flat on top of the door frame, lift the edge of the face where the hinge used to be.
    • Position the catch plate so that the boss on the catch plate will go through the rounded rectangular hole.
    • Replace the catch plate.
  14. How to Switch the Door Swing, Replace the catch plate cover: step 14, image 1 of 3 How to Switch the Door Swing, Replace the catch plate cover: step 14, image 2 of 3 How to Switch the Door Swing, Replace the catch plate cover: step 14, image 3 of 3
    • Take the catch plate cover with the three screws already in position and place it down over the catch location.
    • Use a T25 Torx driver to replace the three 15.4 mm‑long screws securing the catch plate and cover.
    • You may need to lift the inner door face and the catch plate together to allow the screws to thread into the catch plate.
  15. How to Switch the Door Swing, Replace the inner door face: step 15, image 1 of 1
  16. How to Switch the Door Swing, Replace the strike: step 16, image 1 of 3 How to Switch the Door Swing, Replace the strike: step 16, image 2 of 3 How to Switch the Door Swing, Replace the strike: step 16, image 3 of 3
    • Slide the strike into the slot on the chassis across from its original location.
  17. How to Switch the Door Swing: step 17, image 1 of 1
    • Use a T25 Torx driver to replace the six 15.4 mm‑long screws securing the strike.
  18. How to Switch the Door Swing, Re-install the door: step 18, image 1 of 3 How to Switch the Door Swing, Re-install the door: step 18, image 2 of 3 How to Switch the Door Swing, Re-install the door: step 18, image 3 of 3
    • Position the door so that the hinge plate engages the slots in the chassis.
    • The door will stay in place without the screws when properly installed.
    • Use a T25 Torx driver to replace the four 15.4 mm‑long screws holding the door hinge to the front panel.
    • You're done and ready to start swinging!
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 51
