How to Stabilize the Stem of a Longwise ES06 E-Scooter
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 1, image 1 of 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 1, image 2 of 2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 2, image 1 of 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 2, image 2 of 2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 3, image 1 of 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 3, image 2 of 2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 4, image 1 of 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 4, image 2 of 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 4, image 3 of 3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 5, image 1 of 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 5, image 2 of 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 5, image 3 of 3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 6, image 1 of 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: step 6, image 2 of 2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Maithili Admane
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 615
