How to Restore Icy Soles on Jordan 11's
  1. How to Restore Icy Soles on Jordan 11's, How to Restore Icy Soles on Jordan 11's: step 1, image 1 of 2 How to Restore Icy Soles on Jordan 11's, How to Restore Icy Soles on Jordan 11's: step 1, image 2 of 2
    • Use a sponge with some soap and water to scrub the soles of your shoe thoroughly.
  2. How to Restore Icy Soles on Jordan 11's: step 2, image 1 of 1
    • Use an X-acto knife or spudger to gently scrape the dirt from between the grip indentations of the sole.
  3. How to Restore Icy Soles on Jordan 11's: step 3, image 1 of 1
    • Pat the shoe dry with a towel or clean rag.
  4. How to Restore Icy Soles on Jordan 11's: step 4, image 1 of 2 How to Restore Icy Soles on Jordan 11's: step 4, image 2 of 2
    • Use an X-acto knife to cut out tape to match the sections you don't want to apply the cream to.
    • Be careful that you don't damage your shoe as you cut the tape.
  5. How to Restore Icy Soles on Jordan 11's: step 5, image 1 of 2 How to Restore Icy Soles on Jordan 11's: step 5, image 2 of 2
    • Apply the Salon Care 40 cream to the bottom of the shoe.
  6. How to Restore Icy Soles on Jordan 11's: step 6, image 1 of 2 How to Restore Icy Soles on Jordan 11's: step 6, image 2 of 2
    • Use a small paintbrush to spread it around the sole of the shoe.
  7. How to Restore Icy Soles on Jordan 11's: step 7, image 1 of 2 How to Restore Icy Soles on Jordan 11's: step 7, image 2 of 2
    • Wrap the sole and surround the sides of the shoe tightly with plastic wrap.
  8. How to Restore Icy Soles on Jordan 11's: step 8, image 1 of 2 How to Restore Icy Soles on Jordan 11's: step 8, image 2 of 2
    • Set the shoe out in the sunlight.
    • The amount of time to let it sit in the sun depends on how much sunlight there is. If the sky is clear then you can leave it for 30-60 minutes. If the sky is cloudy or it's getting dark you are safe leaving it for 1-3 hours.
    • Do not leave it out too long in direct sun or the sole may peel off.
This guide may need to be repeated multiple times to achieve the results you want please follow all the steps in this procedure as many times as you need.
Arabo
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 26
Past 30 Days: 117
All Time: 368
