How to Replace a G-Shock GA201-1A Battery
  1. How to Replace a G-Shock GA201-1A Battery, Battery: step 1, image 1 of 3 How to Replace a G-Shock GA201-1A Battery, Battery: step 1, image 2 of 3 How to Replace a G-Shock GA201-1A Battery, Battery: step 1, image 3 of 3
    • Remove back cover by removing the four 6.2 mm Phillips #0 screws with the screwdriver.
    • Be careful not to lose the screws.
  2. How to Replace a G-Shock GA201-1A Battery: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the rubber gasket by lifting it.
  3. How to Replace a G-Shock GA201-1A Battery: step 3, image 1 of 2 How to Replace a G-Shock GA201-1A Battery: step 3, image 2 of 2
    • Lift the white plastic covering with a pair of tweezers.
    • Be delicate; if too much force is applied, the watch's interior can pop out.
  4. How to Replace a G-Shock GA201-1A Battery: step 4, image 1 of 1
    • Peel off the protective sticker from the surface of the old battery.
  5. How to Replace a G-Shock GA201-1A Battery: step 5, image 1 of 1
    • Use tweezers to bend the metal guide away from the old battery.
  6. How to Replace a G-Shock GA201-1A Battery: step 6, image 1 of 1
    • Remove the old battery from the guide with tweezers.
  7. How to Replace a G-Shock GA201-1A Battery: step 7, image 1 of 2 How to Replace a G-Shock GA201-1A Battery: step 7, image 2 of 2
    • Slide the new battery into the frame and bend the metal guide onto the battery.
  8. How to Replace a G-Shock GA201-1A Battery: step 8, image 1 of 2 How to Replace a G-Shock GA201-1A Battery: step 8, image 2 of 2
    • Reset the proper time and date using the top-left "adjust" button.
    • For further instructions, consult your G-Shock GA-201 User Manual.
To reassemble your watch, follow these instructions in reverse order.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cordell Johnson
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 24
Past 7 Days: 134
Past 30 Days: 519
All Time: 19,167
