How to Replace a Curtain Rod
  1. How to Replace a Curtain Rod, Curtain Rod: step 1, image 1 of 2 How to Replace a Curtain Rod, Curtain Rod: step 1, image 2 of 2
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: step 2, image 1 of 3 How to Replace a Curtain Rod: step 2, image 2 of 3 How to Replace a Curtain Rod: step 2, image 3 of 3
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: step 3, image 1 of 2 How to Replace a Curtain Rod: step 3, image 2 of 2
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: step 4, image 1 of 2 How to Replace a Curtain Rod: step 4, image 2 of 2
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: step 5, image 1 of 1
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: step 6, image 1 of 2 How to Replace a Curtain Rod: step 6, image 2 of 2
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: step 7, image 1 of 2 How to Replace a Curtain Rod: step 7, image 2 of 2
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: step 8, image 1 of 2 How to Replace a Curtain Rod: step 8, image 2 of 2
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
Finish Line
Andrew Pfeiffer
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 45
All Time: 1,134
