How to Replace a Bicycle Bell Disc
  1. How to Replace a Bicycle Bell Disc, Disc Bell: step 1, image 1 of 2 How to Replace a Bicycle Bell Disc, Disc Bell: step 1, image 2 of 2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: step 2, image 1 of 2 How to Replace a Bicycle Bell Disc: step 2, image 2 of 2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: step 3, image 1 of 2 How to Replace a Bicycle Bell Disc: step 3, image 2 of 2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: step 4, image 1 of 1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: step 5, image 1 of 2 How to Replace a Bicycle Bell Disc: step 5, image 2 of 2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: step 6, image 1 of 2 How to Replace a Bicycle Bell Disc: step 6, image 2 of 2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Your bell should now be ringing like new!
Susan
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 77
All Time: 585
