How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp
  1. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp, Spice Lab Himalayan Crystal Salt Lamp Bulb Replacement: step 1, image 1 of 1
    • Rotate the power switch in the counterclockwise direction to halt electricity flow to the lamp.
    • Be sure to unplug the lamp to mitigate risk.
    • Wait 5-10 minutes to allow the bulb to cool before continuing.
    • Salt lamps, especially this model, are very dense and capable of causing damage to you or your environment if dropped.
    • Be sure to perform this fix on a sturdy and level surface.
  2. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: step 2, image 1 of 1
    • Flip the lamp so that the base is accessible.
  3. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: step 3, image 1 of 1
    • Using your hands, pull the black circular light fixture out of the salt lamp.
  4. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: step 4, image 1 of 1
    • Using your fingers, twist the light bulb in the counterclockwise direction to remove the bulb.
  5. How to Replace The Bulb In A Spice Lab Himalayan Crystal Salt Lamp: step 5, image 1 of 1
    • Screw an E12 light bulb into the empty socket.
    • E12 light bulbs are 12 millimeters in diameter.
Hopefully this fix has reinvigorated your salt lamp. Thank you for using our guide
Matthew Atwill
145 Reputation
1 Guide authored
One Comment
replacing salt lamp bulb is not a big deal , but finding a good salt lamp bulb which lasts long is hard
Jackie Sullivan - Reply
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 22
All Time: 5,575
