How to Repair the Broken Toe Strap of a Fabric Sandal
  1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: step 1, image 1 of 2 How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: step 1, image 2 of 2
    • Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
  2. How to Repair the Broken Toe Strap of a Fabric Sandal: step 2, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 2, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 2, image 3 of 3
    • Slice through three connecting sides at the bottom of the rectangle using a box cutter.
    • Keep your fingers away from the box cutter to avoid injury.
    • Create shallow slices to avoid cutting through the sandal.
  3. How to Repair the Broken Toe Strap of a Fabric Sandal: step 3, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 3, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 3, image 3 of 3
    • Insert a toothpick into the bottom slit.
    • Use the toothpick as a lever to wedge open the flap.
    • Use an extra toothpick if the first one breaks.
  4. How to Repair the Broken Toe Strap of a Fabric Sandal: step 4, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 4, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 4, image 3 of 3
    • Slide the toe strap through the hole of the sandal until you feel resistance.
  5. How to Repair the Broken Toe Strap of a Fabric Sandal: step 5, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 5, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 5, image 3 of 3
    • Flatten the toe strap against the insole of the sandal.
  6. How to Repair the Broken Toe Strap of a Fabric Sandal: step 6, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 6, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 6, image 3 of 3
    • Apply the glue to the toe strap and inside the flap of the sandal.
    • Wear protective gloves to avoid skin irritation.
  7. How to Repair the Broken Toe Strap of a Fabric Sandal: step 7, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 7, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 7, image 3 of 3
    • Close the sole flap.
    • Press the flap down until it is even with the sole of the sandal.
  8. How to Repair the Broken Toe Strap of a Fabric Sandal: step 8, image 1 of 2 How to Repair the Broken Toe Strap of a Fabric Sandal: step 8, image 2 of 2
    • Use the trigger clamp to tightly press the flap against the sandal.
  9. How to Repair the Broken Toe Strap of a Fabric Sandal: step 9, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 9, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 9, image 3 of 3
    • Tighten the trigger clamp by squeezing the trigger.
    • Leave the trigger clamp on the sandal to dry overnight.
  10. How to Repair the Broken Toe Strap of a Fabric Sandal: step 10, image 1 of 1
    • Remove the trigger clamp by pressing the quick-release button.
  11. How to Repair the Broken Toe Strap of a Fabric Sandal: step 11, image 1 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 11, image 2 of 3 How to Repair the Broken Toe Strap of a Fabric Sandal: step 11, image 3 of 3
    • Pour rubbing alcohol onto a paper towel.
    • Rub the paper towel over the shoe to remove pencil marks and excess glue.
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
Kulthum Lakha
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 79
All Time: 2,652
