How to Repair a Loose Rear Bicycle Wheel
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: step 1, image 1 of 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: step 1, image 2 of 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: step 1, image 3 of 3
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: step 2, image 1 of 2 How to Repair a Loose Rear Bicycle Wheel: step 2, image 2 of 2
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: step 3, image 1 of 2 How to Repair a Loose Rear Bicycle Wheel: step 3, image 2 of 2
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: step 4, image 1 of 2 How to Repair a Loose Rear Bicycle Wheel: step 4, image 2 of 2
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: step 5, image 1 of 2 How to Repair a Loose Rear Bicycle Wheel: step 5, image 2 of 2
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: step 6, image 1 of 3 How to Repair a Loose Rear Bicycle Wheel: step 6, image 2 of 3 How to Repair a Loose Rear Bicycle Wheel: step 6, image 3 of 3
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: step 7, image 1 of 3 How to Repair a Loose Rear Bicycle Wheel: step 7, image 2 of 3 How to Repair a Loose Rear Bicycle Wheel: step 7, image 3 of 3
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Lily Suggs
145 Reputation
1 Guide authored
UC Davis, Team 4-8, Andersen Winter 2023 Member of UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
3 Members
1 Guide authored
One Comment
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 62
All Time: 563
