How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer
  1. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the top panel: step 2, image 1 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the top panel: step 2, image 2 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the top panel: step 2, image 3 of 3
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the top panel: step 3, image 1 of 2 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the top panel: step 3, image 2 of 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer: step 4, image 1 of 2 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer: step 4, image 2 of 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the cover plate: step 5, image 1 of 1
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  6. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cover plate: step 6, image 1 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cover plate: step 6, image 2 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cover plate: step 6, image 3 of 3
    • Remove the cover plate.
  7. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Disconnect the cord: step 7, image 1 of 1
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  8. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cord: step 8, image 1 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cord: step 8, image 2 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the cord: step 8, image 3 of 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the cord terminal block: step 9, image 1 of 1
    • Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
    • Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
  10. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Move the cord terminal block: step 10, image 1 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Move the cord terminal block: step 10, image 2 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Move the cord terminal block: step 10, image 3 of 3
    • Move the cord terminal block behind the rear panel.
  11. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the rear panel: step 11, image 1 of 2 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Unfasten the rear panel: step 11, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a 1/4 inch nut driver to remove the eleven rear panel screws.
    • Ten 20 mm-long screws
    • One 12.9 mm-long screw under the water inlet.
  12. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer: step 12, image 1 of 2 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer: step 12, image 2 of 2
    • Use a 1/4 inch nut driver to remove the 16.4 mm-length screw holding the main board bracket to the chassis.
    • Use a 1/4 inch nut driver to remove the two 20 mm-long screws from the top rear of the machine.
  13. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the rear panel: step 13, image 1 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the rear panel: step 13, image 2 of 3 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Remove the rear panel: step 13, image 3 of 3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Reassembly information: step 14, image 1 of 2 How to Remove the Rear Panel of Your Whirlpool WED87HED Dryer, Reassembly information: step 14, image 2 of 2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 47
All Time: 258
