How to Remove Stock Stereo Head Unit in a Toyota Tacoma
  1. How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Bezel Removal: step 1, image 1 of 2 How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Bezel Removal: step 1, image 2 of 2
    • Ensure that the vehicle is off and the battery is disconnected.
    • Remove the plastic trim pieces by pulling them straight back.
    • Pulling from behind the vents on each side one at a time is the smoothest way to pull the panel off.
  2. How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Unbolting the Unit: step 2, image 1 of 2 How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Unbolting the Unit: step 2, image 2 of 2
    • Unscrew the four bolts on the sides of the stereo using a 10 mm socket with a ratchet or an impact driver.
  3. How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Removing the Stereo from the Dash: step 3, image 1 of 1
    • Carefully remove the stereo out of the dash to expose the wires in the back of the unit.
  4. How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Disconnecting the Wiring: step 4, image 1 of 3 How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Disconnecting the Wiring: step 4, image 2 of 3 How to Remove Stock Stereo Head Unit in a Toyota Tacoma, Disconnecting the Wiring: step 4, image 3 of 3
    • Remove all 9 wires from the back of the stereo by pushing down the safety clips and set the unit aside.
    • Have someone hold the stereo while disconnecting the wires.
Sean
139 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 14
Past 30 Days: 50
All Time: 1,285
