How to Open the GuliKit KingKong 2 Pro
  1. How to Open the GuliKit KingKong 2 Pro, Unfasten the back cover screws: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: step 2, image 1 of 2 How to Open the GuliKit KingKong 2 Pro, Insert an opening pick: step 2, image 2 of 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: step 3, image 1 of 2 How to Open the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: step 3, image 2 of 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. How to Open the GuliKit KingKong 2 Pro: step 4, image 1 of 2 How to Open the GuliKit KingKong 2 Pro: step 4, image 2 of 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. How to Open the GuliKit KingKong 2 Pro, Remove the back cover: step 5, image 1 of 2 How to Open the GuliKit KingKong 2 Pro, Remove the back cover: step 5, image 2 of 2
    • Separate the back cover from the front assembly and remove it.
Dominik Schnabelrauch
206,326 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 137
All Time: 5,614
