TiVo Series 2 TCD24008A Power Supply Replacement
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: step 1, image 1 of 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: step 2, image 1 of 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: step 3, image 1 of 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: step 4, image 1 of 1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: step 5, image 1 of 1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: step 6, image 1 of 1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: step 7, image 1 of 1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: step 8, image 1 of 2 TiVo Series 2 TCD24008A Power Supply Replacement: step 8, image 2 of 2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Phil Jones
41 Reputation
1 Guide authored
Cal Poly, Team 5-33, Amido Fall 2011 Member of Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,211
