How to Fix the Worx Pegasus Workbench lower tray
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: step 1, image 1 of 2 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: step 1, image 2 of 2
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: step 2, image 1 of 2 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: step 2, image 2 of 2
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: step 3, image 1 of 2 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: step 3, image 2 of 2
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: step 4, image 1 of 1
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
Finish Line
RodCastler
193 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 242
