How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 1, image 1 of 1
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 2, image 1 of 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 2, image 2 of 2
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 3, image 1 of 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 3, image 2 of 2
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 4, image 1 of 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 4, image 2 of 2
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 5, image 1 of 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 5, image 2 of 3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 5, image 3 of 3
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 6, image 1 of 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 6, image 2 of 2
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 7, image 1 of 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: step 7, image 2 of 2
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
2 other people completed this guide.
Ani Gurtsishvili
235 Reputation
1 Guide authored
7 Comments
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - Reply
it still has the two lights blinking
kresge - Reply
directions did not help, the yellow and ogange till blinks
kresge - Reply
it did not work
kresge - Reply
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - Reply
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 217
All Time: 11,338
